It is currently Sun Aug 17, 2025 12:48 pm
PostPosted: Mon Sep 22, 2014 7:44 pm
Last Name: Jeffries
City: Williamstown
State: NJ
Zip/Postal Code: 08094
Just wanted to get a general idea of how you personally prefer to do it, and your reasoning behind it...
PostPosted: Mon Sep 22, 2014 7:49 pm
First name: sam
Last Name: guidry
State: michigan
Country: us
Before and after. Before, to a rough template so final profiling with a radius dish, after, is quicker
PostPosted: Mon Sep 22, 2014 8:09 pm
Last Name: Colbert
City: Anacortes
+1 for uvh sam..
PostPosted: Mon Sep 22, 2014 9:34 pm
Me too.
PostPosted: Mon Sep 22, 2014 10:42 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Close before, fine tune after. It is a lot easier to cut a flat board than a bent side.
PostPosted: Mon Sep 22, 2014 11:18 pm
First name: Aaron
Last Name: Craig
State: Missouri
I prefer to bend sides at a uniform width, which is typically just a bit wider than the final dimension at the tail. Once the tail and head blocks are in, a small block plane quickly gets things close enough to move to a dish.
Aaron Craig
PostPosted: Tue Sep 23, 2014 12:08 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I've done it both ways. I currently like roughly profiling while flat, then bending and gluing, then later getting things perfect with a dished sander. I have more useful leftovers this way. You have to pay more attention during bending, though. Having two left sides is no big deal if the wood stays a uniform width, but it is a replacement level mistake with pre-profiled sides.
PostPosted: Tue Sep 23, 2014 12:24 am
Two steps as well. Before the bend, then final with radius dish. This way, you can nearly always take a set of bindings off the sides. Our general practice is to rip the bindings, profile the sides, then put the bindings back on near where they came from for a beautiful color match...Image
PostPosted: Tue Sep 23, 2014 12:27 am
PostPosted: Tue Sep 23, 2014 12:56 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
This is very true, but, you will only do it once. I hope.(doh!)
Everyone finds what works best for them. Me I hate sanding, so i get the sides close and then place the sides on a radius dish, scribe and plane as necessary. I also do the braces this way.
PostPosted: Tue Sep 23, 2014 5:52 am
I do profile before before bending as it saves a lot of work . Bending a 5 in wide pieces makes for a lot of work to taper and radius the sides. On Classicals I don't think it would matter that much as they don't have the same amount of taper as a steel string.
PostPosted: Tue Sep 23, 2014 7:13 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I've only done classicals thus far, and do it as Aaron has described. Cut the sides to the dimension of the tail (tad higher), bend, and then plane a slight taper on the back of the sides down to the head block, once the sides are glued to the top. Very little sanding needed.
PostPosted: Tue Sep 23, 2014 1:44 pm
Last Name: Lloyd
I also do it as Aaron and Martin have described with the profile drawn on the sides before bending. A small block plane makes for short work. Though I must say I have been tempted many times to cut first but always seem to go the safe route. :)
Michael Lloyd
PostPosted: Wed Sep 24, 2014 7:43 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I cut my sides to be as tall as the end block. I then bend. Then I profile them with a plane, and finish up with a radius sanding board. No real profiling prior to bending.
PostPosted: Wed Sep 24, 2014 12:39 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I profile before bending, and I do not use a radius dish.
I don't know if I'd recommend this method to a beginner because gluing the blocks has to be perfect, but it works for me.
PostPosted: Wed Sep 24, 2014 12:51 pm
Here's where a CNC and CAD/CAM software can come in really handy...
I created a 3D model of my last OM, and then created the cut file for the sides. Bend, and then I simply glued on the linings a hair proud and use a radius template (also made with the CNC) to sand the linings to the correct curvature, and then glue on the back.
My top rim stays mostly flat.
PostPosted: Wed Sep 24, 2014 1:13 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I do it like Nils. It doesn't take long to make the profile with a sharp spokeshave. Then sand it to radius in the dish. I might try profiling first on the next one. I don't see a reason why not to do that. Cutting the profile on the band saw would be quick.
PostPosted: Wed Sep 24, 2014 3:28 pm
ME too. I've done it both ways. I started off prebending but found that if I leave them square it helps if I over shoot the bend and end up with some cut off which would place the predefined profile off line. I use a hot pipe to bend so I guess if using a bender it would not matter.
PostPosted: Wed Sep 24, 2014 5:37 pm
First name: Tom
Last Name: West
State: Nova Scotia
Yes, same way here...!
Tom
PostPosted: Wed Sep 24, 2014 7:44 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I prefer to have my sides flat when bending. I use a silicone heating blanket. /bending form .My tops are flat. Having 2 flat sides .I have the option of choosing which one to profile , so I can get some contrast in the grain of the sides. I use laminated sides , so there is extra work involved. I run a fine pencil line on the inside of the sides in the mold sitting on the 15 ft back radius dish. I profile quickly on the trusty rockwell 6 by 48 sander . glue in the blocks, a quick radius sand and the back is glued on with fish glue , it too is sometimes laminated. Top is glued on last .the current one is WRC with balsa lattice bracing
PostPosted: Thu Sep 25, 2014 4:44 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Only one thing to add- I usually bend on a hot pipe and profile sides later with a block plane. Last build I smacked off a chunk of the sides with the front on the plane and had to repair. So, watch out what you're doing with that plane!
We are all in the gutter but some of us are looking at guitars.
PostPosted: Thu Sep 25, 2014 11:25 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
One of the reasons why I prefer a spokeshave for this task.
PostPosted: Thu Sep 25, 2014 1:34 pm
I use a spoke shave too. [:Y:]
I had the same problem with a block plane once but fortunately I had a lot more room to recover.
PostPosted: Fri Sep 26, 2014 4:37 am
First name: joseph
Last Name: sallis
Country: UK
Yes, I'll not be using a plane again.
PostPosted: Sat Sep 27, 2014 7:27 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I profile after bending. I use a chisel to rough it out and a block plane to smooth the taper. I check by laying a level across both sides and sliding it from the butt end to the neck end. This will show if you have one side higher than the other at any point (assuming your bench is level to start with)
